Engine Noise, Throttle adjusting
Se7eN
Engine Noise
So, about a week ago went ahead and installed a Port Injection system to the car. '15 Fist, once it was al re-installed (done by a mechanic) went to turn on the car and it's making a clacking noise in the engine bay. Does it for about 30 secs or so and then it stops completely. Verified to make sure nothing was loose and yet when ever the car is cold and you turn it on it does it.
Edit: Ok so already verified the throttle, seems to be coming from the pulley system in the car. Gonna check that during the weekend.
Yes you can monitor the actual throttle position with the AP. It sounds like you need to go back to your "mechanic" or better yet, try to find a real "technician" to check out wtf was damaged when the "mechanic" fucked it up.
