Helmet and Headrest Issue
Does anyone else have an issue with the headrest pushing their head forward when they have a helmet on? Has anyone found a work around for this short of changing the seat out?
My helmet doesn't fit when I have my seat in my normal driving position; so I have to fold the seat way back. If I could lower the seat another inch or two...
Sent from my Pixel 2 using Tapatalk
J
Does anyone know what resistor is needed to turn off the airbag light when you change seats?
Looking at it, I don't believe flipping the headrest will give me enough room with the hybrid HANS system.
Woods247
Flipping the headrest or removing it won't work with a HANS. I have to lean my seat back more than usual. I just got use to it..
Plainrt
Also interested in the resistor info if anyone have.
cxwrench
The stock headrest pushed my helmet forward enough to be annoying. I've heard the Focus headrest is adjustable and can work well. I think the resistor should be 3ohm, but don't take my word for it. It was 3ohm in my STi.
I just turn my headrests around backwards.
If that does not work for you why not use the headrest out of a non ST Fiesta Platinum, they are tilt adjustable.
Or for track days with for use with a HANS device, why not any Fiesta headrest, just cut off the top and weld a bar across the two posts to anchor the HANS.
Dave
Plainrt
What year they change the headrest? My 15 had adjustable headrest and my newer fist base seats are ugly non adjustable.
I don't think the FiST ever had adjustable headrests only the Platinum non-FiST.
Dave
Plainrt
Dave
My 15 did. I was mad when found out weren’t on my newer seats.
I experienced this same issue last time I autocrossed. I've got a 2016 FiST with recaros. I tried tacking the headrest off and flipping it, but I couldn't manage to take it off, so I just adjusted it to its highest setting. I haven't really messed with it sense, is there a trick to getting them off?
Search works wonders.
https://www.fiestastforum.com/threads/17554-Headrest-Removal
Dave
There you have it folks, I've been learned. Danke!
RAAMaudio
Also search for the thread on bending it back a bit, using a vice is easiest, works very well for helmet fitment but not sure on using a HANs.
