Help Me Clean My Recaros
So my friend spelt some powerade/lemonade on my seat. It was on the grey part of the recaro. Seems to be like nylon or something. I tried interior cleaners and it made it worse, then I brought it to wash place and it didn't help either. [bash] So now I don't know what to do. There also a few darker grey/black marks on the seats. What should I use for these seats?
AL=x
That's lame, I would get new friends. as for cleaning lemon oil always cleaned up my work clothes pretty good. good luck just my 2 cents
Only thing ive always used is Chemical Guys products for all that kinda stuff. Look them up they sell a cleaner called nonsense works for me
And they have stronger stuff just have a look on there website
Adam's brand Carpet and Upholstery cleaner took care of some grease stains in my Recaro seat, as left by my alignment shop, who decided to remove the plastic seat cover before they were finished. Use the spray cleaner as directed with a nylon brush to agitate and lift the stain.
I would use a steam cleaner for that kind of thing. It has cleaned up pretty set in Dr. Pepper spill stains on my aunt's car seat. Many people may not have a steam cleaner I know, but if you can borrow one or rent one. If you rent one make it worth it and clean your whole car and some other's cars or your house carpet while you're at it.
M
Okay thanks everyone. I am gonna try and find the Adams stuff, seems to be the best bet. If I have no luck there I will get the steam cleaner!
303 multi surface cleaner,
get 2 towels, wet one with water and wring it out so its moist not dripping wet
spray affected area a few times (saturated slightly, wet to touch)
agitate until you see foam with a brush (tooth brush is fine if you dont have any other brush)
take moist towel and mist it with the 303 and cover area for 3-5 minutes
remove towel
if the area is still wet, great, if its dry, spray more 303 on it and agitate again with brush and mop up all the foam immediately with 2nd dry towel.
repeat 2 or 3 times
admire your results
Source: I spot clean all the time, with 95% success.
M
Awesome, I will give this a go.
