I have a tune for the stock MAP so going to try that. If that doesn't work I'm going to go back to oem injectors and hpfp. Ordered a new fuel line to go with the stock hpfp so I don't have to bend it back and forth. Also will do the cam bucket while I'm in there. If the stock fueling doesn't work than the only change is trans/gears/clutch and if that's the case then....well....I might push my car off a cliff.
