Help with Glowshift boost gauge install...
ST_Bo
I have a 2018 fiesta st I'm trying to install a glowshift boost gauge I just don't no where to connect everything for the constant power I had it fuse tapped into the horn for ignition source I had it fused tapped into the radio for ground I connected it to the ground in the headlight switch and headlight source I had it plugged into a purple an white wire of the headlight switch I think the ground or headlight source switch is where I'm having the problem I'm clueless with cars but I love my fiesta and I want to do everything my self with this car and learn along the way any help would be appreciated
XanRules
Did you get this figured out? If not, I will crawl around under my dashboard and see if I can remember which wires I ran where, since the interior is currently stripped out of my car and this would be fairly easy.
ST_Bo
ST_Bo
No I still didn't get it figured out the only way I got it to work is running all 3 wires straight to the battery with a fuse I tried multiple fuses for the ignition wire and can not get it figured out
XanRules
oh yeah do NOT do that. Okay. I'll crawl around in there when I can and see if I can figure out which wire went where.
