Help
Yarpol
Columbus, OH, USA
Do you guys know if a
17X8 BOLT: 4X114.3 OFFSET:35 would fit in terrible at wheel shit
Twin Falls, ID, USA
Hey Bro, no problem. But no, wouldn't fit (wrong bolt pattern). A tool I use all the time when I want to get schwifty on wheels is willtheyfit.com. That wheel size would be money with our bolt pattern 4x108. The link below shows you current setup to new setup with poke size, so forth.
https://www.willtheyfit.com/index.p...ct2=40&wheel_size=17&wheel_width=8&offset2=35
Yarpol
Columbus, OH, USA
God never any perfect fit bronze or gold wheels okay okay one more than I’ll actually use the website these probably don’t fit but I’d like your wisdom I always hear people say they like 16” on their fiesta
4 PCS ROTA GRID 16X7 PCD:" 4X108"OFFSET:42 HB63.35 GOLD https://www.amazon.com/dp/B07TTVV5RC/ref=cm_sw_r_cp_api_i_m381Eb2SJC752
Twin Falls, ID, USA
Yeah, those would work. I like a little smaller rim with a touch more rubber (I'm on 15" rims). Going down a size on the rim you'll also need to adjust tire size. The tire size listed below would be what I would use and don't forget TPMS sensors (if you don't rip to stock ones out).
Tire: 205/45R16
TPMS: https://www.amazon.com/gp/product/B0034ROE76/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
New Layout (near match of OEM fitment): Compared to your existing wheel, this new wheel will have an inner rim which is 5mm further away from the suspension strut. The outer rim will poke out 5mm more than before.
https://www.willtheyfit.com/index.p...ct2=45&wheel_size=16&wheel_width=7&offset2=42
