Infernal rear knocking!
I've checked all the usual culprits. Parcel shelf, rear seat squabs, spare wheel well, I've folded the rear seats down - no difference.
Rear right side, usual low speed of rough roads. Sounds like a knock, kinda hollow. I've removed the wheel arch liner and the shock seems fine, including the sleeve thing around it. Rear springs are good and I've replaced the isolators.
Any known culprits? Car drives right, suspension feels good.
check the bushing where the suspension beam mounts to the body. Those have a fair amount of give in them to begin with, so if worn out, could be a noise point.
Breandawg
Axle bushings is a possible culprit, though they look fine. Worth investigating further. I'd consider replacing with polyurethane but I've heard that reduces the cars propensity for liftoff oversteer, which would be a great shame!
The exhaust was swinging about but I've replaced the old hangers with polyurethane and it's good now.
A rear numberplate late was rattling in it's housing, I fixed that too, sadly it didn't cure the knocking.
Downsy
How many miles/kms? I generally consider suspension bushings on a street driven car done for around 100-150k miles depending on how you drive it. Also pull out the cargo floor and spare tire and make sure something didn't wind up down there rolling around.
Breandawg
70k miles. I've checked under the spare wheel well good. If not the bushing itself could it be the shock itself? I suspect not by who knows.
The car does get thrown around roundabouts quite a bit ;) not excessive fast or aggressively, but it probably takes a toll on the bushes.
LilPartyBox
My rear has knocked every winter since new through the OEM suspension and 2 aftermarket setups. Once spring rolls around up it goes away every time
Breandawg
That's nuts! It's pretty cold here at present and it has seemingly exacerbated the issue.
Downsy
Could be but if it was internal to the shock you should be able to hear it by rocking or bouncing the car at a standstill. You could also inspect the brake hardware. Sometimes things can get loose. I had a scraping noise an thought I had wheel bearing going out in the rear, Took the wheel off inspected the brakes and found a thumb sized rock had somehow found its' way between the brake pad and the caliper bracket. It was loose enough to only cause noise when turning.
Breandawg
I should've mentions I checked the brakes, I rebuilt all of them recently. Good point re bouncing the car. I've tried they and get a bit of creaking but not this knocking sound.
