Installed a 2j intake on my 18 fiesta and has a high idle
Looking for suggestions on why my car has a high idle I went to a 2j intake from stock I need to do a new purge valve but idk what would be causing a high idle fluctuations usually idles around 1000-1500rpms with the occasional idle drop but other then that the car runs and drives fine comes into boost as it should
Any check engine light/ MIL light on?
Check the PCV routing. Mine came loose after installing new turbo and caused it to idle high. Tons of other things it could be as well, but that’d be the most obvious first thing I’d check.
