Intercooler dimensions
I can't seem to find it during a search. Can I get exact dimensions of our intercooler?
Overall length, length from the center of inlet to outlet, overall height and thickness.
BoostBumps
Razorlab originally compiled this list (below) awhile back of Intercoolers by core dimensions...However it doesn't fully answer the question you were asking regarding overall length (inlet to outlet) but does provide core Length, Height, Thickness, and in some cases Weight...
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Approx. 5lbs
Core Volume:
288.75 in
The list is in order of Core Volume.
Mishimoto J-Line IC**
Core Dimensions:
22" x 7.2" x 3.75"
Approx. 19lbs
Core Volume:
594 in
69.1589% difference over OEM FiST IC
18.1818% difference over Cobb IC
Cobb IC
Core Dimensions:
27.5" x 6" x 3"
Approx. 13lbs
Core Volume:
495 in
52.6316% difference over OEM FiST IC
5.6075% difference over ATP IC
ATP IC
Core Dimensions:
24" x 6.5" x 3"
Core Volume:
468 in
47.3736% difference over OEM FiST IC
1.2903% difference over AIRTEC IC
AIRTEC IC
Core Dimensions:
28" x 6" x 2.75"
Core Volume:
462 in
46.1538% difference over OEM FiST IC
9.4122% difference over Mountune IC
Mountune IC
Core Dimensions:
29.25" x 5.75" x 2.5"
Core Volume:
420.47 in
37.145% difference over OEM FiST IC
3.4401% difference over OEM FoST IC
Stock FoST IC**
Core Dimensions:
26" x 6.25" x 2.5"
Core Volume:
406.25 in
33.8129% difference over OEM FiST IC
4.0816% difference over Levels IC
Levels IC
Core Dimensions:
26" x 5" x 3"
Core Volume:
390 in
29.8343% difference over OEM FiST IC
19.6224% difference over Mishimoto Z-Line IC
Mishimoto Z-line IC**
Core Dimensions:
26" x 5" x 3"
Core Volume:
320.31 in
10.3635% difference over OEM FiST IC
Azov
Yeah I found that list, but I'm trying to find a more universal or different car intercooler. The volvo s40 is a very close fit.....I think until I can get some more exact dimensions.
Hijinx
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Approx. 5lbs
Core Volume:
288.75 in
?? Is this not what you wanted?
Azov
Stock FiST IC
Core Dimensions:
27.5" x 5.25" x 2"
Approx. 5lbs
Core Volume:
288.75 in
that's the core size. I'm looking for the overall size with the end tanks included.
Azov
Went out and measure my old IC hanging in the garage and L=40.3/8 H 6.1/8 W 4.7/8 with elbows
Perfect thank you very much.
rodmoe
Welcome and don't hold me to the N'th degree on these measurements as they were done with a tape measure and eyeball.. my old eyeballs lol but they are close
Azov
http://www.amazon.com/gp/aw/d/B00ST...ntercooler&dpPl=1&dpID=51o6+E4j81L&ref=plSrch
I'd almost say that this is pretty close to being a direct bolt on. The core is essentially the same size as the J-line but with 90 degree end tanks and what looks like mounting brackets about where the stock set should be.
The biggest problems I see is either the height at 7.75" and the 2.75" diameter
Hijinx
It won't fit. Comparing measurements won't tell you the whole story. But feel free to try it out in case I'm wrong.
For example, our end tanks aren't 90*. It's more like 110*. The inlet/outlet are also centered on core. Good luck with accessing them. Half of this unit will probably have to stick out underneath the car once you do get the piping matted up without kinks.
What are the max dimensions of an intercooler for the '14 ST? I was looking at this one. It says it's "universal fit", but I don't buy that:
It seems like it would be too tall and deep: almost 12" in height, and 3" deep.
I have purchased the hot/cold side pipes from depotracing. Do I need all the extras (i.e. 2.5in 90* Coupler, T-Bolt Clamps, Direct Fit Brackets, Aluminum 2.5in Joiners) with the purchase of an intercooler?
J2FoRS
From my finagling and measuring and dicking about, I decided for myself that absolute max height is 11" which may still touch or require losing the lower cowl of the bumper. So 10" clean and no more than 2.75" thick. 3" is no go. 2.5" is clean through, 2.75" MAY touch where the crash bar curves. Obviously this goes behind the crash bar.
