Why not? I got no money left for some of the more expensive stuff I would like to do, so here are the early beginnings of my cheap sprayer. Started by disconnecting the rear washer hose from the pump since I never use it. Use the existing barb on the pump to attach some 4mm washer hose at $0.50/ft. Five way T fitting $0.79. Vacuum caps for T $0.15. Disconnected the wiper motor in the rear so it doesn't come on every time I presoak, free. Now I am out to find some fogger nooozles to finish it off.
I'll report back once I get it strap in. Then some test logging.
Here are the nozzles I picked up at the grow shop. 0.5gph foggers. I just shoved one into the hose to see the pattern. Seems good but positioning them will mean eveything to make good contact. I haven't ruled out drilling some holes in a small od pipe to try more of a manifold approach.
My version of a rear wiper delete. Pulled the wiper, pulled the hatch panel, unplugged/unbolted motor assembly. I inserted a 7/16x1 stainless bolt thru the rubber existing wiper gromment and backed it with a nut and washer. I didnt bother with a locknut because once you compress the rubber a little it will add tension to the bolt.
