Intermittent starting (Crank no start)
So recently have an issue with intermittent starting. It would drive fine. I go to park and restart shortly after and the car would just crank with no start. Had it towed the first time and as I got home the car start right up of drove it off the tow truck (Smfh $375 later!). Up until now I can start it and drive but with out notice it will act up and not start! Right now there is no current codes so I’m kind of lost as where to start.(fuel, crank sensor) I was hoping to reach out to the community before I start the self diagnosing as time is very limited for me.
*I can remember back a few weeks ago I had the car stall on my as I got out to go into a store. But back then car started right up and I thought nothing of it.
Greatly appreciate any input!
How old is the Battery?
M
due for a new one! 3yrs... that was one of the things I checked with my booster pack the night I got stuck ;(
Did you actually take it out and load test it and charge it? When was the last time the key Fob batteries were replaced?
M
No ddnt load test it. Key fob was changed about a yr now
Did you try the other key if you have one? Does it do anything at all when your trying to start it? Does the engine try to start/fire or is it nothing at all?
xxiaze
Starter teeth possibly broken in some places. Would be my guess... when to starter tries engaging it’s possible that it’s not making correct contact with the flywheel. Hence why it will start sometimes, but because it might be broken the more you do it the more you will sheer the cog. Do you live in a rust prone climate? As for it dying at the store, that could be your battery due to an alternator.. seems to me based off your symptoms you have multiple issues.
Business6
This is only after the engine is warmed up? Not on cold starts? Any mods?
Se7eN
Does it throw codes of any kind? I've seen similar issues in other cars with faulty Evap solenoids and such.
M
I going to say yea after engine is warmed up! Cold starts for the most part are good. Mods e40 tune,BT, Aux fuel
M
No codes! Someone mentioned evap. Is there more than one solenoids??
Se7eN
Just one up front under the intake and then there is the evap canister in the back under the fuel tank
Business6
One step colder plugs, by chance?
I've been Running...1 step and 2 step colder plugs with no issues in starting it at all in Temps ranging from 90° to -20°. Fires up every single time* what i wanna know is what it does when he tries to start it....does it turn over/ fire or nothing at all or just click*
If I had to guess, as most of the above are, I would look at the crank sensor first.
The crank sensor is mostly only used for start up, one that is starting to go bad or intermittent, could be it.
M
Thread Starter #18
The engine turns over but no start....keeps cranks but won’t start
No codes? Though....right?
