Low boost! Cant do More that 5psi of boost
México
Hi guys! I just dont know what else to do! I replace the boost solenoid, my mechanic did a smoke test AND he states that there was no leaks, i put a new cobb intercooler AND a dizzy stage 2 map. With the accesport i did a couple of datalogs AND i cant do More that 5 psi of boost, wgdc ITS on 75% so i do not know what else do i have to check, my Guessing Is that my gfb dv+ Is stuck, any opinión? Thank you in Advance.
Burlington, NC, USA
Diverter valve is a good place to check. Boost leaks also don’t often show up on a smoke test because there’s very little pressure.
M
México
I checked For boost leaks everything looks fine, all clamps AND hoses, i replace my gfb dv+ For the oem bov. I changed maps from dizzy to cobb, i make shure that there wasnt on eco mode. AND nothing !! I still cant get More than 5 psi! I don't know what else to check
M
México
Ok! Sorry For the delay, the problem was a sensor behind the steering wheel behind the airbag, this sensor detects when the car is turning left or right, it wasnt properly calibrated, the car wasnt properly alligned, so because of this the car goes to limp mode. We replace this sensor and the car is working great! 22 psi of boost
