Low Boost
Quisp
Davenport
I'm not getting over 16.5 on my fist. Uninstalled AP , pressurized from hot pipe to cold side hose holds 10 psi , loosened and tightened all clamps. Surges at 2500 rpm steady throttle. Can this be diagnosed through logging ? I have GFB DV+ and removed and inspected it. Bad wastegate actuator or boost control valve ? Dealer service dept says it's meeting all demands from ecu. Won't even break tires loose.
Chino Hills
Does the brass piston for the GFB dv fall into place, or does it take a bit of effort to seat it? If it falls in place you have a knockoff! I ran into a similar issue.
GAbOS
The AccessPort has a gauge for clutch sensors. If one is off the ECU will imp boost. I accidentally knocked one out (there are two that each read 50% of the throw) while working under the dash.
Quisp
Quisp
Davenport
Clutch switch reads out good. I bought the GFB from rally sport it's been on for at least 6 months and been fine. Adam looked at the logs and has suggested maybe bad coil pack . Have thrm on order. Thanks for the suggestions .
Quisp
Quisp
Davenport
Fixed . it was diverter. Not sure the GFB was part of it but there was a domed metal piece with a hole at the tip loose . I left it out but problem persisted . looked like off tip of actuator. Thank you Adam for looking over Adam and CMZ builds for diverter.
Quisp
Quisp
Davenport
Found problem with DV+. The plunger o ring is gone. I'm sticking with the replacement stock diverter from England.
