LPFS/ Low Pressure Fuel Sensor DIY
Well i popped codes of P0087 Fuel rail pressure/system pressure too low and P008a Low Fuel pressure detected in the system.
Here is a list of tools I used to do the repair.
1. Gather tools
3/8 ratchet
3/8 stubby ratchet
3/8 to 1/2 inch adapter
15/16 Deep socket
Two long 3/8 extensions
Towel
Skinny Arms
2. If you have skinny Arms like I do....put the Towel preferably a medium sized one down near the sensor which is at the supply line into the HPFP near to exhaust manifold. The towel will be used to catch an excess fuel that may come out and prevention of a car-b-que. You can see the sensor barely here but the towel is underneath it. DO THIS ON A COLD CAR ALSO TO PREVENT BURNS.
3. Get your sensor out. Here is the part number and what it looks like. It will fit nicely into the 15/16ths deep socket also BTW. If you have small Arms like me...i could fit them in between the Intake pipe and finaggle the Stubby onto the old sensor. It doesn't take much to undo/ remove the old one either. Unscrew the old one and remove it. Then install the NEW ONE BY HAND NOT WITH THE TOOL TO AVOID CROSSTHREADING IT. Spin it down until it can be turned anymore.
4. After it is Finger tight get the Two long 3/8 extensions and link them together or use one long one. Then you will put the socket onto the sensor and then insert the extensions through the little area by the intake pipe to the socket and tighten the sensor. DONT HE-MAN IT ON THERE. It is maybe a 1/4 turn thats it.
5. Start up the FiST and check for leaks and erase codes and go hauls ass during the test drive....I know I did!
6. Most of all have a Happy 4th of July
How many times has the code popped up so far? Mine ran funny like it was missing when I was just lightly passing someone on the highway. No codes until I was setting up a new scanner at work at just scanned the FiST for shits and giggles and I had that code and one for the torque. Cleared it and it just came back on a few days ago. I'm at 67K. I thought it was just bad gas because I got it a Circle K in OK.
Sent from my SM-G973U using Tapatalk
2x
Woods247
@TyphoonFiST did you relieve the fuel pressure before removing the sensor? I’m about to attempt this today. I gotta remove the cowl and/or induction hose to get to it though. I still haven’t been able to locate it back there.
I just let the vehicle sit for a couple hours and cool down. Best idea EVER. [emoji362] it is very easy to do. Difficulty on a 1-10 ...10 being Rocket surgery and 1 being playdoh....I give it a 1.5 out of 10.
Woods247
Ok cool. Since the time I posted, I managed to remove both cowls and induction hose to get a better view. Is this it?
I've been getting soft codes for P018C and P008A (Low Pressure Circuit and Low Pressure Fuel System, Low...)
Just replaced the pump after I thought it sounded like it was going out... turns out that is normal... I'm going to try the sensor next and if neither fix the problem... I really don't wanna go any further on my own haha.
Hypergram
I also have been experiencing those codes, the 18C one persisting after clearing. Did replacing the sensor remove those codes?
Yes, the low-pressure fuel senor behind the engine did the trick. Was not AT ALL the fuel pump, but at least I have a new fuel pump for peace of mind haha.
Hypergram
Did the same today myself! Along with the towel, I popped out the fuel pump relay/fuse and ran the car until it died before swapping out the sensor; still got 2-3 teaspoons of gas on the towel so I'm glad I did it. Needed the 24mm to get the original sensor off as it was really on there tight, and taking out the intake hose (not crossover) helped a lot too for the additional space. After a light spray down with some water and some time to evaporate all codes were clear and the car ran fine. Thanks for the write-up!
Fin
I wanted to mention this in case other people have similar symptoms maybe this will help.
I had a very strong gas smell
coming from my car. (2016 90k miles) I replaced my evap purge valve a while back (maybe around 60k a few years ago) so I knew this wasn’t the issue. I was getting codes P008A and at one point P018c and when i replaced the low pressure fuel sensor this fixed my issue. I now no longer have the codes nor the gas smell. so the sensor going bad can be the raw gas smell. or (potentially just the O-ring around the sensor could of went bad and may could save you the money) (sensor cost me 50$ on rock auto for motorcraft genuine sensor) hopefully this helps
Thanks for posting this! Replaced the sensor today after getting p008a, p018c, p219a codes and a CEL time will tell if it fixes the issue but seems to be running smoother now. I'd probably put this job at a 3/10 for difficulty just because my old sensor was insanely snug and it's hard to get torque on it since the line is flexible. Taking off the middle intake section definitely helped get more room
TDavis
Wonder if this would cause ONLY a p219a code?
On my way to work this morning, coasting to a stop sign and the engine would not idle down. Was idling at about 1500RPM's... wrench light came on the dashboard then it began to stutter and cough, and the gas pedal would do nothing.
Shifted to first and literally sputtered it to the side of the road. Left it idling for a minute or so and all it did was sputter and cough like I said before with no gas pedal response. Shut it down and waited a couple minutes, then I tried starting it. It fired right up and seemed to run fine. At this point I just wanted to get it home as fast as I could, so I turned around, and it was running perfect!! No check engine light, no more wrench light!
Tonight, I checked for codes with my accesport and got P018D "Fuel pressure sensor B circuit high". Found this thread and decided to check it out. Long story short, when I found the sensor right where TyphoonFist and woods247 said it would be (thanks for the great info guys) I was like, "why is there nothing plugged into the connector"? The damn plug must have vibrated out, absolutely no idea how but it was friggin unplugged.
I have no idea why it gave me no problems driving home (about 7 miles) but it did not.
Just wanted to write this to maybe give another scenario of problems and/or codes that could lead back to this sensor. Again, thanks for the great info, guys it wasn't a bad sensor, but it was 100% related to it and because of this thread I was able to quickly find where the issue was!
