Lug nut help
I was reading somewhere that the size of the stock lug nuts is 19mm but my 19mm socket doesnt fit tried a 20mm and it kinda just gets stuck onto the bolt anyone know the correct size or what kind of lugs i should replace them with?
If you don't want to deal with spline lugs:
WheelGuard 1957, Bulge Acorn Lug Nut, 12mm-1.5, 3/4" (19mm) Hex, Chrome Plating (20) https://www.amazon.com/dp/B01N459459/ref=cm_sw_r_cp_apa_uilCAbG69V52T
DEss
I just got these from Amazon. CJ Pony parts also sells them. After reading about the issues with our OEM lugnuts, I went for forged steel. I won't actually install them until I put my OEM wheels back on in the Spring. The reviewers on Amazon are correct, they come covered in what looks like rust dust. I'm beginning to wonder if its not some preservative Gorilla uses. Getting them cleaned up involved rinsing with hot water then in the oven for a while at 150 degrees to dry the threads. It took 5 minutes. So its worth ignoring some of the crybaby reviewers on Amazon.
https://www.amazon.com/gp/product/B00SF8F5T0/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
these are the ones I got to fit my xxr527 wheels.
hope these pics help you, otherwise call dealer and ask for parts dept and they'll inform you
