My turn for a thread on overheating.
Lots of INTUITs post deleted, ...........
Liar. Just stop.
....... As for running lean one can run lean with absolutely no heat issue but a serious fueling issue it used to happen back in the day not so much with more modern ecu’s and whatnot. Though it is a way to make an engine go boom. Lol .........
Your engine went boom? I though it overheated. Does damage only mean boom? Just stop it.
#43
Liar. Just stop.
Liar? Lol I was talking about editing all the stuff you wrote man you seem angry.
I had an overheat once but I did not make a big deal about because I knew the reasons why. There was no damage.
#45
Keep attacking the person and character rather than the points that were actually espoused.
It seems like that is what you are doing. Here by calling me a liar.
I am not doing that and you are severely misinterpreting what has been written. I had to go back and realize that you were not drunk you were assuming stuff that had not happened.
Sorry if I called you drunk when you were not. I do think you need to give it a rest you seem awfully worked up over this. Oh and thats not an attack but a suggestion. Relax.
T
Rochester
Thread Starter #48
who wants an update?
well 3 months later I just picked up my car from the Ford dealer. They installed a brand new long block under warranty. head gasket failed between cyl 2 & 3 is what they noted.
happy to have my car back, it drives good, but has a clunk on start up. I'm going to check all the motor mount bolts soon as I really don't want to drop it off again.
3 months? Hopefully they covered a rental for that entire time! What a bunch of meatballs! I'm surprised they just didn't declare long block right away and get it done and back on the Road.
T
Rochester
Thread Starter #50
Yes. I had a Jeep loaner covered which is the only reason I didn’t care. Ford wanted to just do a head and the dealer wanted a long block. The dealer won when ford didn’t have any heads available but did have a long block.
also, the total cost from start to finish was $9k or half of what I paid new for the car. So I’m glad this was covered.
ROCKYFiestta
Colorado Springs
#51
ford quality at its finest. I had an overheat over the summer did the same thing spiked up to max but I was running the ac maxed out and it was 96 degrees outside nothing seems to have happened though I just turned off the ac and kept driving slowly home and it cooled down to normal levels fast once the ac was off. i plan of getting that 180 degree thermostat done this spring before i need the ac again and maybe get a new radiator.
Seems a little odd that it only overheated on A/C max setting. There was a recall for a high speed fan relay.
If Ford paid $9k it sounds like the dealer got over. Almost half of that is probably lot fees from it sitting.
T
Rochester
Thread Starter #53
From all that I’ve read the cooling systems on these cars are ok at best. More capacity of fluid is probably what I would do. I think my car had a defect from new.
Quisp
Davenport
#54
I'm sure there's a logical explanation but it seems to be hit or miss. I'm in central Florida with an X47r and even in stop and crawl traffic I never get near overheating. I believe some have found defective stock radiators perhaps pinched off or blocked passageways.
Sent from my SM-A205U1 using Tapatalk
