Oil and Spark Plugs
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
As the title says, I found some oil on my spark plugs. Not on the electrodes, but in the well. Explains why I have random negative corrections. Has anyone had to replace their valve cover gasket?
dyn085
Vancouver
No, but oil outside of your plugs shouldn't be leading to negative corrections.
Hijinx
Hijinx
Auburn, AL, USA
If a little oil got into the cylinder it wouldn't cause knock?
dyn085
Vancouver
It would in theory, but I just don't see it being a possibility as you would probably have to be losing a lot of oil that way. Most of the time when people have oil there they find their plugs to be perfectly normal when removed.
rexdriver85
Allentown
The oil would have to make it down past the spark plug threads and that's pretty unlikely.
Hijinx
Hijinx
Auburn, AL, USA
Yeah, the plugs were fine and my oil level is normal as well. What would you suggest? I dive in and change the gasket out, or just keep an eye on it?
dyn085
Vancouver
I would probably just keep an eye on it personally, under the assumption that it's not completely flooded with oil. The Mk3 Focus had the same issue on a bunch of cars and people would go have it replaced under warranty just to have the issue resurface, so it mostly just became tail-chasing. I had the issue with mine but it was negligible so I just cleaned it more often.
Hijinx
Hijinx
Auburn, AL, USA
Understood. Thanks for the input. [drinking]
