P1443c with MAP intake.
Los Angeles
So i bought this FiST brand new from the dealership. I installed a MAP intake. I have noticed that i started getting P1443c (Evap). Any ideas on what it could be? I connected all the lines properly. Should I take the car to the dealership?
LilPartyBox
NYC
there was one oem hose that had to be cut off to install the vacuum hose. maybe you cut too deep or in a way that prevents the good seal?
M
Los Angeles
Ok ill look into it. I called MAP and they said that that had been the first call they have received on that issue. Also not that it may relate but it always happens when im at less than half tank of gas.
Pittsburgh
Takes like 50-100 miles to come on after being installed/code cleared. I checked all the fittings last night quick (all fine). Have to reset the cel yet
