Part No. for the CV joint boot?
maestromaestro
I have a CV joint boot that split. I suppose it is called technically the outer passenger side CV joint boot. There are kits that I see on the interwebs, but I'd like to make sure that I got the correct part number...
Anybody with that knowledge - for the MY2015 FiST?
The boot kits I'm seeing online from the Ford parts stores are like $70 that's insane. It almost seems like you'd be better off just buying a new CV axle. My brother installed one of the universal CV axle boot kits on his Ford Focus it works but it was a heck of a mess to install.
maestromaestro
maestromaestro
Tasca has them for about $70 or so, which is quite annoying for what the kit actually includes. And, although it looks identical to the passenger side, the driver's side kit is $4 more for some reason. Are there some universal boots, like something Dorman makes? Dorman makes a split boot (which is obviously easier to install, but kinda defeats the purpose) that looks similar for $20...
It may look easier to install the split boot but you have to clean everything really well, and you actually have to use a included adhesive plus clamps to put both sides together. You also have to do some cutting on the ends as they are oversized. This is just my personal experience with my Brother doing this on his Ford Focus it was quite a hassle in my opinion.
maestromaestro
maestromaestro
I hear that. But - pulling out the half-shaft or at least pulling it out at the CV joint is a hassle as well. I wonder what it the lesser of the two evils...
True very true. I'm sure you can handle installing a universal kit just fine. It's just a little messy.
