Pierce rear torsion beam for Autox?
Hi all,
Been looking for a rear bar for HS for some time. I have a chance at a Pierce rear bar but haven’t been able to find much info on it (mm thickness etc). I have a ‘15, so stiffer spring rates with thinner sway bars.
Worth it or should I wait for something else?
Which bar are you talking about? The beam stiffener? Or a roll bar?
Any stiffening of the rear will increase rear rotation. Conversely, stiffening the front makes the car tighter.
I have both the torsion bar and the sway bar on the rear for track. At first, it felt snappy loose, but I got used to it.
I would assume getting rotation for AutoX is at a premium. So, I think you add it to the rear.
tri-pedaler
Beam stiffener. Looking for a 19mm since I have a ‘15, so the Pierce is a bit thick
