Project build from canada
So hey my name is michael, im from Canada and here is my 2017 Fiesta st ! Not dyno yet but will be at the beginning of summer. Whats are your though on this build ?
All the parts that has in coming beside is that i didnt bought it yet but will be in the next few weeks so if you have that for sale let me know or ill buy new !
List:
Vogtland coilover
Vision 16" wheels
Falken azenis
Rear wiper delete
Wing riser
Rally armor mudflap
Window tint
2" antenna
Side marker flasher
Boomba short shift plate
Hp tuners
Big costum intercooler
Cold side pipe cp-e
Hks bov
Cpe boost tap
Dizzy adapter tap
Aem boost sensor
Dizzy boost sensor
Cobb hot charge pipe
Mishimoto cold air
Gt28 oversize to gt35
Exhaust manifold oversize
Radium crankcase catch can
Radium Second catch can
Tial 18psi wastegate
T-map bosh 4 bar
Turbosmart cel defender
Perron 4 port aux kit 95lbs injector
525lph in tank fuel pump
Boomba throttle body spacer
Atp 3" catless costum downpipe
Muffler delete
Split second injector ecu control
Velossa tech
Boomba rear motor mount
Aem fuel pressure regulator
Hp oem ecu adapter to regulator
Zex wet kit
Zex bottle heater
Zex purge valve kit
Upr pro serie check valve
One step colder plug
Vr plug and play wire for aux
Dizzy ethanol content gauge flexfuel kit -- in coming
Ortiz costum pillar gauge pod
Boost gauge
Nos gauge
Air fuel gauge
Temperature gauge
Coolerworx full short shift ---- in coming
Lsd ---- in coming
Lightweight front crashbar --- in coming
Lightweight rear crashbar --- in coming
Camshaft v2 + spring + arp bolt --- in coming
Cp-e side motor mounts
Eibach swaybar kit --- in coming
WELCOME! [thumb]
Are you going to be driving this through your winters up in La Belle Province??
If so, I suggest NOT doing so on the RT615K+ donuts. [wink]
