Rear break won’t compress.
Sebastian, FL, USA
So I was changing out my rear breaks and one side won’t compress. It stuck closed. That break has been rubbing while driving. Do I need a new caliper? Anybody know the part #? Or could it be something else?
FiestaSTdude
Cary, NC
F
Sebastian, FL, USA
You need a special tool that screws the piston into the rotor. Watch the video below they explain it fairly well.
View: https://m.youtube.com/watch?v=EpbklSjrpsU
https://www.harborfreight.com/disc-brake-pad-and-caliper-service-tool-kit-11-piece-63264.html
Here’s the tool I bought to do it.
Thank you sorry I should have stated I have one. I got the other side screwed in fine. On this side I screw it and it doesn’t move
CSM
Cleveland, OH, USA
IIRC, the rear calipers are very cheap on these cars. If it were me I'd just get a new caliper vs. rebuilding, although a rebuild kit is very cheap too
F
Sebastian, FL, USA
Thanks CSM I’ll probably do that. We’re do you recommend purchasing new calipers? I’ve had a hard time finding the right ones
the duke
Cleveland
Bin it and order a whole new caliper. Replace the slide pins and grommets on all corners as well to just get that out of the way.
Use caliper specific grease
