S280 🐌 Coming soon! need advice ⚠️
So i just got a new fiesta, I have an s280 turbo lying around from my old fiesta and its going into the new ST asap BUT need some Advice.
I have dp (catted or uncatted) will I make more HP on the Catless DP? I've heard you make less on Catless.
Intercooler
Wastegate
Charge pipes
exhaust
Single port Aux fuel injection
E85 at my disposal (for e40 e50 tune)
The whole shabang
How much hp should I be making?? On E85 blend
Should I add the
Bosch 4 bar T-Map Sensor 2014+ Fiesta ST / 2013+ Focus ST
AEM 3.5 BAR / 50psi MAP sensor kit 2014-2019 Fiesta ST
(For more hp?)
What eles would you add and how much are you making on this exact setup?
(SIDE QUESTION) what is the sizing for the manifold to turbo studs/bolts?
Any IC engine is a glorified air pump, the more air you can exhaust, the more air you can inhale... So catless will lessen the restriction in exhaust and allow more flow but a turbo is a massive restriction so a catless DP isn't needed for a street car performance, not to mention it's illegal in most municipalities...
Also map sensors will not provide more HP, just allow you to see boost above 29lbs and therefore tune for it.
__diegoortega__
This car is my new track car, it won't see a normal road.
Catless will have higher potential HP. For a track car, I can make an argument in favor of running a catted DP but honestly I haven’t seen anything that would suggest there will be much of a difference at the power levels were talking here. There is some evidence that catless makes less low end torque on the tiny stock turbo.
Upgraded sensors will just allow you to tune more accurately for more than 29 psi because the stock sensors can’t read beyond that. Definitely a good idea but beyond that is where you’re looking at a higher probability of sending a rod into orbit.
For track days, I run a conservative tune even though I have enough turbo and fuel for 375whp. I personally wouldn’t go much beyond 300whp on a track tune where you will be running it wide open all the time, but if you decide to max it out you should be able to get north of 330whp if I had to guess.
Can’t comment on the studs. I’m lazy so I just call the ford dealership, tell them what I need, and let them do the rest lol.
__diegoortega__
Solid, Solid comment. Thanks a lot brother. And yah lol I was lazy too so I wanted other people to do that research 😂 I found extra though so it's all good.
