Thats cool and please excuse my female ignorance with the next question but if it is really well stuck on what happens when I need to change the wheel ?
Like This Post Yes
Yup. from the back with a large round cylinder a good whack will get them off unless you really scuffed the rim and added a lot of glue. [MENTION=4960]eglove[/MENTION] any plastic safe eoxy would do the trick. The hot glue should also work. My only worry is that you may not have the center cap stolen but you may get the rim and center cap damaged. Another option could be to get a simple vynil to go over the hole. Does not need a center cap as long as the vinyl is 5 mm larger than the hole. THat is what I did as I did not like my center caps.
