Stock internals boost.
Jedhardy
Hey everyone, I've seen a few threads about it, but have yet to find a specific answer. How much boost can I "safely" put into stock internals? With a cobb stage 1 im sure most of you know will push about 18-19 pounds. That's seems crazy to me. Can it handle much more, with everything internal stock? I'll for sure have to change out injectors and fuel pump and what not. I'm mostly concerned about bigger problems like will pistons/pistons rings and bearing and earthing old up with more boost?
Jabbit
New England
25+ on stock internals on a stock, hybrid, or s280 turbo will be fine all day everyday.
akiraproject24
U.S. Marine Veteran
Pennsylvania
I'll tend to peak at 26.45. On a custom tune, tuner let me know the stock turbo was maxed out after the 2nd revision.
Of course on some days it doesn't get over 26. I think that's due to getting the torque requested at lower boost or something like that.
Wichita, KS, USA
Been running 26 on a Dizzy tune for the past year, no problems whatsoever. They can run mid 20's without any issues.
San Jose
I thought the stock map sees 21-22 psi on premium during overboost?
Capri to ST
CHAPEL HILL, NC, USA
I believe you're right, when I asked Ford Performance what the boost PSI was stock, this was their response-
"In general the car will boost from 13-22 psi at wide open throttle depending on conditions, gear, RPM, etc."
Mikey456
Los Angeles
I’m running the same Cobb stg 1 tune. I would be more concerned about boost leaks and heat. In my opinion, if I wanted to run more boost I would delete the sound symposer, run colder plugs (if recommended by tuner) install an intercooler and possibly a radiator (in a hotter climate/track work). But that’s just me being conservative on the car.
