Stratified E30 combo tune or separate map files?
Reynoldsburg
I'm thinking about dipping my toe (jumping head first) in the E30 waters. I already have a Stratified 93 octane tune. What are most people doing accessport-wise? Getting the existing tune converted to a combo tune or getting a separate tune file? What are the pros and cons of each?
Butterybunz
Minneapolis
There's no reason not to have them on the same file and be able to switch between the two via the cruise control buttons. That way if you're in a pinch and can only find 93 octane you can switch back on the fly.
codestp202
CA
I personally have a DHM 91 tune, then I just got a Stratified e30 tune. They are different tunes and I can always reflash to 91 if I have to. Will take a minute compared to instantly.
However, their e30 tune is AWESOME!!!
Hijinx
U.S. Air Force Veteran
Auburn, AL, USA
The only reason not to have them on the same file:
Accidentally being in the E30 slot when you fill up with 93.
G
Reynoldsburg
Thanks everybody. I'm leaning towards a combined tune file. I'll have to ping Stratified to make sure I'm ordering correctly.
George
alexrex20
Spring
I went with the separate file, even though I could've just had my existing 93 file modified. I don't anticipate needing to instantly change maps so I couldn't care less about map slots. It only takes 60 seconds to reflash anyway.
