Finally did a test of the 3D print fitment jig. First version was a little off (too conservative) near the base of the spokes, so I’ve uploaded a corrected version accessible at the same link.
I printed at draft quality and 10% infill to keep it a fast print and save material. Hopefully it’s self explanatory, but the tool goes inside your wheel, the round boss goes in your wheel’s hubcentric ring, and the flat face up against where the hub mounts with the lug nuts. See pic inside my Dekagram (you can kind of see the place I adjusted the jig where it looks too close even though the actual caliper clears)
The rest of the jig shape represents the location of the caliper and the rotor. You should rotate it back and forth to make sure the spokes clear everywhere. Check your wheel weights as well. Unlike the paper template, the print is sized to the *actual* caliper - the required 3mm min clearance is not included already. You should be able to slip the 3mm shim in between the jig and the wheel at *all* points in order to have sufficient clearance.
The STL print file also includes a 1” cube to verify the dimensions of the jig are accurate, as well as a convenient 3mm shim tool for checking clearance. The whole print is sized to just fit on a 180x180mm build envelope so even small budget desktop printers should be able to make it.
