Switchback's Fiesta Fun Car Build
EscortSportage
U.S. Marine Veteran
NY
#41
Ah, my bad. Coolant piping you’re good, it’s the cold side charge pipe from intercooler to throttle body that won’t fit with a bigger radiator.
Ill have to trim the plastic around the cooling fan, I was looking at this yesterday since you mentioned it. Seems like the fan assembly will be the issue.
S
San Diego
Thread Starter #42
It’s been a minute since I last posted here, but work continues! I recently installed the Pierce Motorsports tow hook kit, but made a bit of a change to the design.
As you who have installed this kit know, you have to *somehow* get a pair of bolts and washers inside the crash bar to hold the bracket in place. Instead of doing that (and hating life) I used a rivnut tool we have been using on the Lemons project. It worked perfectly and from my research is as strong (if not stronger) than the original washer and nut setup Pierce includes with the kit.
While I was in there, I also replaced the center bumper support as it was broken. The bumper no longer sags as much! The original piece is held in there with hot glue so after the tedious process of peeling it off I got some new hot glue (the industrial heavy duty stuff) and glued on the new bracket.
EDIT: apparently mobile safari doesn't like to embed images properly. I'll fix it tonight when I'm home from work.
S
San Diego
Thread Starter #43
My bad luck just keeps on coming. While swapping out the turbo for a slightly used one and installing new exhaust manifold studs, I found that one of the previous owners snapped one of the exhaust manifold studs (far passenger side). This is very possibly why I was having low boost, if the exhaust manifold was leaking/warped.
I'm seriously starting to wonder if I should just rid myself of this Fiesta and go get something else.
