Tubular Exhaust Headers - Yay or Nay?
shouldbeasy
Calgary, AB, Canada
[VIDEO=youtube;azPKIjxmmdU]https://www.youtube.com/watch?v=azPKIjxmmdU[/VIDEO]
So... think this video applies to Turbo cars? What are the implications with introducing a turbo into the exhaust stream?
shouldbeasy
shouldbeasy
Calgary, AB, Canada
Implications would be do the dents effect spool?
My thoughts exactly. But due to drop in flow area, speed increases on the exit... But after that, sustained pressure perhaps becomes the issue?
But really, I'm just looking for someone in he turbo world to say that this is BS in our application.
Or it's true, and exhaust headers don't mean shit.
frankiefiesta
forked river
I'm not turbo scientist lol but my opinion is this..
Stock turbo or hybrid turbo, the stock log manifold is great.
When you go big turbo you will want a tubular manifold that can flow better and more efficiently. For example, ATP kit uses stock manifold, and lags like a MF. Deadhook big turbo kit uses tubular manifold and it helps with spool. Especially when you look at the two side by side. I can try to find some graphs of the two
Weymouth
It comes down to flow and velocity vs pressure. Low pressure or in terms of piping can cause low velocity. Think blowing through a large straw vs small. Your main objective is flow and if your exhaust has enough velocity this isn't an issue but if it doesn't then you loose power. Before and after the Turbo are two different things and before the Turbo is more important in terms of velocity. The proportions have to be correct or you will loose power or response. It is not as easy as bigger is better.
This is kind of complex and I don't have a PHD in thermodynamics but there really isn't a simple answer as to what gains are had by modified exhaust. N/A is also very different for a Turbo. You can get by with certain things on a Turbo you couldn't on an N/A engine. I'm sure scrounging the internet will verify this with dyno charts and when bolting on parts with a Turbo vehicle you can usually see gains everywhere. On an N/A engine it is give and take usually with a trade for TQ over HP. Goes back to flow,velocity, and pressure except on an N/A engine you are using atmospheric pressure and thus why you see a trade off.
Basically to me that video showed the headers are more then enough to support the flow of that engine. They are also very simple in design, start adding crazy bends and loops and the results may be different with collapsing tubes and disturbing flow. There is a point of diminished performance it just wasn't met.
