- Member ID
- #372
- Messages
- 1,560
- Likes
- 142
Thought i would do a little down pipe upgrade today after work, followed Airjor13's write up. all was going smooth untill...
step 6. "Break" the 3 bolts (10mm) holding the DP to the hot-side of the turbo, top 2 are accessible from the top, the 3rd one is easier from the bottom. Once the DP is free, remove the small plate by the shifter cables, 3 bolts, when you see it you will know what I am talking about.
i dont know if Ford knows what Never Seize is but i got 2 of the bolts out after spraying with Deep Creep, still took a while and a slow go as they were in for life.
Bolt number 3 the upper one you cant see without sticking your head way in there came out nice until the last third of the threads it suddenly jammed up, so i tried to put it back in and try out again but it jammed some more. left it sit with some Creep on it for a bit and when i came back it started to turn until a sharp and sudden SNAP...
i am so Fnckin pissed right now i could burn the car and whoever decided that exhaust bolts should be installed without Never Seize on them.
off to ford it goes i guess. Unless someone can give a suggestion!
