- Member ID
- #11691
- Messages
- 497
- Likes
- 574
I've been a Manufacturing Engineer it automotive since 1982 and mainly work in Exhaust and Fuel system components for the Major automakers. As a result one thing that stands out on the Whoosh pipe is the missing and poorly performed Hose beads at the tube ends. The purpose of these beads is to insure that the hose won't pull off if there is tension placed on the hose. So I have to give Woosh a D- on those beads, they will have zero pull off resistance. I strongly suggest that everyone installing one of these pipe tighten the hose clamps really tight. BTW, simple pressure inside the tube can act to blose the hose off if the clamp slips. If you take a 1.5 inch diameter pipe and run the numbers a pressure of just 14 psi inside that pipe and produce 106 lbs of linear force on that hose connection.
To Ron at Woosh. Mckean Machinery Sales in Brookpark Ohio sells used manufacturing machines. While they aren't always available they do have Eagle I/O machines available fairly often, sometimes with prices as low as 1000 dollars. Note, make sure to ask if the machine is Relay Controlled or PLC Controlled. If it's a PLC controlled machine give it a pass. Because quite often these machines have been powered down for years and have lost the programming for the PLC controller, a program that is unobtainable. If it's relay controlled it will always have a control system that is easily repairable, typically swapping in new ice cube relays is all that is needed. The most common failure point on these machines is the rubber spider in the motor couplings for the two hydraulic pumps, a bit of a PITA to replace but not nearly as difficult as replacing the radiator on the FiST. The next thing you'll need is a set of bead tools and those can be purchased brand spanking new for under 1000 dollars if it's a basic design. The company that currently owns the Eagle brand is AddEaton by Numalliance in Lebanon Ohio. BTW, PM me and I can design set of these tools for your specific bead and email PDF design drawings for these tools.
