whoosh motorsports Intercooler Boost Hose kits HAVE ARRIVED! Pics inside!
felopr
JD
#61
you are a tough man to please but I'm going to keep trying!
I need some good news today.....my 2 old friends had to be put down last night. Our last 2 rescued greyhounds....
Having a shitty day!
man, sorry to hear that. I have 3 dogs and i will be sad if one of them die, imagine 2
I went outside and took some pics ;)
Ford ST
Pleasant Garden
#62
I am sorry for your loss. My black lab is turning gray on me. You're a cooler dude then I thought. I have recommended you multiple times on my YouTube on the st200 airbox.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #63
Thanks
I'm still adjusting.
We gave them a good life....have to keep the good memories in the front of your mind!
So back to business....I'm really anxious to see someone with a full set of purple installed both induction and boost hose kit. I'll make a deal if anyone is interested that will take good pics. Message me!
jeff
Evans
#64
Hey folks...I'm in the process of researching this...looks like a great product, just 2 questions before I buy this along with the metal noodle...
1 - the clamps for sale with this kit appear to be similar to the stock ones on the car...is there any difference or are you re-using the OEM ones?
2 - lots of WHOOSHING and whistling turbo noises being reported here....of course, it is WHOOSH motorsports but seriously I'm a bit confused because some reviewers of other kits report only a very mild sound increase while others (like on this thread) report a significant one....what's the deal?
Thank you in advance.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #65
If you decide this route Jeff I'll send you the kit (boost hoses, clamps, and j-pipe) at half off for a fair review
Our hoses are lined and tight tolerance which is why we went with standard silicone suitable clamps. The end user doesn't need to crank down on everything with t-bolts to keep them in place
some connections may require some hairspray because they are so tight
as for the j-pipe or noodle pipe, most replace this when going with the boost hose kit because you are already removing everything and there is no good reason for the sound baffle on the OEM pipe. Once installed , the j-pipe may increase sound and flow a bit but it's more of making things right in my opinion. We offer these pipes for $79.99 w/FREE SHIPPING and there is a forum discount available as well
let me know and thanks for considering this option
jeff
Evans
#66
Ron that's awful kind of you. I'll take you up on that and I'd like the RED color please. Let me know via PM how to go about getting the kit (boost hoses, clamps, j-pipe) as you mentioned and I will be happy to do my usual detailed review and youTube video review also and hopefully get you some good business. If you have recommendations for other minor stuff you think could make small improvements before I head to the dyno let me know, I might add that to the order.
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #67
here's the kit
ready to roll when you are...
PM sent
Bowie
#68
Oooo Iā€™m definitely going to pick this kit up when I put my order in fit your v2 fmic
SST
Toronto
#69
any diagram to show where these 6 pieces go and the j pipe? from the pics above, i found 5 total
Spork1569
Ventura
#70
I installed these myself and what I found easiest is to remove them one at a time and compare them to the sizes of the originals. If you delete the symposer you will have an extra hose.
Using that method I was able to find the cold side easily as they are among the bigger hoses, and the one where the cold side connects to the engine is quite small, the hot side has one small one connecting to the turbo, this is where you replace the J pipe after and then there will be 2 after the J pipe to connect to the intercooler(with a plastic pipe in between)
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #71
ron@whoosh
ron@whoosh
Vendor
Las Vegas
Thread Starter #73
so if i already have the MBRP hot side pipe, any duplicate piece here?
you would have one extra piece left over after install (the small 2" 45 degree bend that goes between the OEM j-pipe and OEM hot pipe)
