15"x7". Offset is 30mm, Hub bore is 73mm Thanks Sent from my iPhone using Tapatalk
ElijahSky Member May 5, 2016 #1 Member ID #1147 Messages 93 Likes 39 May 5, 2016 #1 15"x7". Offset is 30mm, Hub bore is 73mm Thanks Sent from my iPhone using Tapatalk
polyol Member May 5, 2016 #2 Member ID #4605 Messages 30 Likes 1 May 5, 2016 #2 What size tire? Fender clearance would be the issue...obviously...
OP ElijahSky Member May 5, 2016 Thread Starter #3 Member ID #1147 Messages 93 Likes 39 May 5, 2016 Thread Starter #3 Probably 205 50. I wasn't sure about the 30 offset but thought it would be close. Sent from my iPhone using Tapatalk
polyol Member May 5, 2016 #4 Member ID #4605 Messages 30 Likes 1 May 5, 2016 #4 It may be close, might require a slight fender roll.
OP ElijahSky Member May 6, 2016 Thread Starter #5 Member ID #1147 Messages 93 Likes 39 May 6, 2016 Thread Starter #5 It looks like the lowest offset I can run without trouble is 35mm right? Sent from my iPhone using Tapatalk
