Hi guys,
I've had my Wilwood front BBK on for about 7 months now and approx 10000km (6000 miles)
I have the BP-20 pads and my car is pretty much a city commuter and yesterday was the first time I really took it above 80mph on this BBK. I tracked the car prior to this on stock brakes but these Wilwoods have never seen track/autox use.
Yesterday I was on the highway and even pressing the brake lightly I could feel pretty noticeable vibration through the steering wheel but around town <40mph there's never been any issue. I can brake fairly aggressively from 50mph and it will brake straight with no steering vibration whatsoever. I didn't try braking hard >80mph
I don't think it's a wheel balancing issue as there's no noticeable vibration just cruising along at 80mph, only under braking.
Here are the pics of my driver's/passenger's side rotors.
Passenger's side is the clean one that looks pretty normal, driver's side has that uniform line going down the middle.
I've read that if you throw an aggressive pad on there it'll take off uneven deposits, I have some Hawk DTC-30's that I can experiment with to test this theory but wondering if it could be something else. I also read that a few hard braking stops from 60-10mph would also help.
I get that vibrations may be amplified at speed but weird for there to be no issues under 60mph and noticeably vibrate over 80mph. The feel of the vibration is similar to an unbalanced or non-hubcentric wheel that wasn't torqued evenly
I will be tracking the car in 2 weeks and going at speeds around 110 mph on the front straight so there is probably need for concern.
