New Big Brake (Rotor) Kit Option
Hey guys. Digging up this old thread. I see Gold coast finally has brackets for 300mm SVT front rotors for the seemingly reasonable price of $125. My question is whether or not it's worth that plus the price of rotors ($100-150) for an extra 22mm over stock. The original kit was slated to be 326mm which is is almost 50mm bigger than stock. These would be used for street and some light to moderate track days. Thanks.
Well now I may have a use for the spare SVT rotors laying around in my car hole! 22mm is a pretty decent increase, should shed heat better. The oem ST rotors seem to hold up pretty good, judging by the folks that run them on here. Nice bump!
Sent from my iPhone using Glue and macaroni
I've been looking around, and I can't seem to find svt rotors for a decent price. Could anyone point me in the right direction. I actually checked rockauto.com and nothing popped up.
Sent from my XT1650 using Tapatalk
slopoke
Howdy, I went with plain rotors to match my Wilwood front BBK kit. I used Centric brand rotors, as they are the budget brand of Stop Tech. For what I want them to do the 125 series rotors will be just fine. I lucked out, one rotor on Amazon was only $14.00 with Prime shipping, it's a shame they only had one. The other was $33.00 from Carid including shipping. I've listed the part numbers below, pretty straight forward.
Total price for the rear upgrade $237.00, including brackets, rotors and stainless steel braided lines. Using the stock pads.
C-TEK Standard Rotor 121.61074
High Carbon 125.61074
High Carbon Cryo Treated Rotor 125.61074CRY
StopTech Sport Cryo D&S Rotor Left 127.61074CL
StopTech Sport Cryo D&S Rotor Right 127.61074CR
StopTech Sport Cryo Drilled Rotor 128.61074CL
StopTech Sport Cryo Drilled Rotor 128.61074CR
StopTech Sport Drilled and Slotted Rotor 127.61074L
StopTech Sport Drilled and Slotted Rotor 127.61074R
StopTech Sport Drilled Brake Rotor 128.61074L
StopTech Sport Drilled Brake Rotor 128.61074R
StopTech Sport Slotted Brake Rotor 126.61074SL
StopTech Sport Slotted Brake Rotor 126.61074SR
StopTech Sport Slotted Cryo Rotor 126.61074CSL
StopTech Sport Slotted Cryo Rotor 126.61074CSR
So for the rear, lately I’ve seen just the SVT brackets used for $140, or autoparts store calipers/brackets for $250. Anywhere lately you can find just the brackets for cheaper?
Rockauto?
slopoke
I paid $150.00 for mine and that's for used ones. They are kinda like looking for a unicorn. So bottom line is do you want to pay around $240.00 or so including braided lines and rotors, or a Wilwood BBK that will cost $1050.00, both is for plain rotors. If you go fancy with drilled or slotted, the price is more. That price for the Wilwood includes braided lines and a parking brake cable kit.
I'm looking into this now, I actually have a set of SVT rotors I'd be using, I see that the kit requires a spacer with the 323mm, anyone know if this is the case for the SVT rotors as well?
If you are referring to the front kit, the SVT (300mm) rotors only fit the NON ST Fiesta.
Dave
