Turbo Pulsing under high boost conditions in 4-6 gear
lessard.dcj
Petawawa
As the title says, when i get on her hard between 4-6 gear i can hear the turbo pulsing. the 2j intake makes it easy to hear.
please help if you can.
lessard.dcj
lessard.dcj
Petawawa
stage 3 now. been seeing some scooby guys having to clean out the boost control solenoid.
rodmoe
wausau
All I can think of is you are hitting one of the limiters in the tune.
JPGC
Middleburg
I know mine will do that slightly at half throttle...but never at WOT.
lessard.dcj
lessard.dcj
Petawawa
Could this be caused by the waste gate if it is not strong enough to hold the requested boost?
Sourskittle
Lakeland
With the stock turbo, the stock wastegate can hold almost anything, or at least, it can hold way more boost to redline than you should be running. What your hearing is the compressor surge you could never hear before. There is a spot between bov opening, and throttle shutting and you'll get a little flutter. Its normal. Cyborg will do it without the 2J intake.
