I am not looking for a significant drop, just a little less wheel gap and better ride. Seems that Eibach's are the ones to go with? Am I missing others? Are the Ford Racing springs compatible?
Is that because Mountune states this in their write-up?
The reason why I'm giving you a hard time is because Mountune, Cobb's Sport Springs, and Eibach Prokits are "all" manufactured by Eibach and designed to work well with OEM shocks and struts....
You really can't go wrong with whomever you chose to purchase springs through...
Like I said earlier Mountune, Cobb's Sport Springs, and Eibach Prokits are "all" manufactured by Eibach and designed to work well with OEM shocks and struts....
You really can't go wrong with whomever you chose to purchase springs through (i.e. Mountune, Eibach or Cobb)...
exactly...oh and cost...Although I was able to get my Cobb's Sport Springs at Eibach Prokit pricing...Always pays to ask for discount and/or price match...
No surprising...There will always be some variation from the original spec to actual measured results from others that have installed them....Eibach, Cobb , Mountune all state a nominal drop to be expected which will vary somewhat....And relatively speaking they are all very close to one another as far as spec'd drops go....
If it's that big of an inconvenience then don't click on it. Just as easy for you to move right along. Most information I was searching was archived, and I also wanted to know if I was missing other brands.
