I'm noticing that the outside air temperature as shown in the gauge cluster is different (usually a few degrees colder) than what's shown as the Ambient Air Temp in the accessport monitor.
This leads me to believe that it's a separate sensor. Anyone know where each of these are?
I know there's one in the driver's side of the cowl that directs air from the upper grille to the radiator... but I'm not sure if this is ambient or if this is the one that's used to show the outside temp in the gauges.
I know that Intake Air Temp is measured in the MAF sensor.
nI'm having issues as well. After installing my Mishimoto cold air intake, my ambient air readings on my AP are all over the place. In he morning they are 10 degrees cooler than what the car is reading on the instrument cluster. As I drive aggressively the ambient air temp shoots up to 10-15 degrees above charge air which is impossible. This all coincided with changing my intake. Not sure what I could have screwed up. Car drives fine, but I know this isn't supposed to be like this and it's driving me nuts. When I had the stock air box with intake hose on, my ambient temps would always be about the same as my cluster outside temp reading. Something isn't right. Any ideas????
