Dead Hook Motorsports Factory Fitment Intercooler!!!
Trader history for DHM (0)
What kind of paint are you using? Also are you doing any flow shaping on the inside at the entry and exit fittings or do they just dump into the end tank? Do the flanges sit flush with the inside of the end tanks or do they protrude inside at all?
Kip2MyLou
I'll be keeping mine raw. I have a black ST and love when the intercooler on cars can be seen. Looks badass, to me.
EDIT: And I just paid for mine! Can't wait. Hopefully they ship out soon. Want to have it one by the next car show, July 19th. Need to get your name out there Russ! Ha.
DHM1
DHM1
Thread Starter #143
Its not paint it is a type of powder coat. The intercooler inlet and out let are flush to the tank surface. As for flow the front tank is on a angle that helps with a back door design like this.
Russ
CanadianGuy
Hey Russel,
I checked the first post and it shows me as not having paid.
[mecry]
I paid a week ago.
[confuse]
The list was more to get it kicked off. Now that [MENTION=1098]drag4life723[/MENTION] got the minimum Russ may not use it to track but it would be nice to know how many members jumped on the order.
DHM1
DHM1
Thread Starter #146
Yup I have hand written order of everyone. I will update the op soon
Any ETA as too when they may ship? Just getting warmer here and ready to install it lol
DHM1
DHM1
Thread Starter #148
Yours should ship out over the weekend. Last night i went through and added people to the op and put them in shipping order. 4-5 will ship thursday. Sorry its taking a little longer than hoped. I wasnt expecting to have that many people jump on board that quick lol. Had to order more material and that took up some time. But im working hard!
Thank you
Russ
CanadianGuy
Thank you
Russ
Your success is your nemesis. Lol. Not a bad thing.
DHM1
DHM1
Thread Starter #151
Here are some logs.
Out side temp was 80deg and sunny.
This is in my shop car.
2015 Fiesta ST
DHM280 EFR Kit
20psi of boost
93oct
about 260whp
Stock exhaust and Stock intake.
This pull was 30-90mph after a couple min of cruising
http://datazap.me/u/drag4life723/dh...-30-90mph-efr-turbo-260whp?log=0&data=3-4-6-7
This was right after the pull above NO COOL DOWN TIME. 60-125mph I wanted to test any heat soak. A light street "worst case scenario"
http://datazap.me/u/drag4life723/dh...mph-hot-efr-turbo-260whp?log=0&data=3-4-6-7-8
Keep in mind that with my stock intercooler i have logs in 150-160deg charge air temps. With out doing back to back pulls lol. I hope you guys can pull some logs before and after to test.
Thanks
Russ
thats awesome..
can't wait to get mine..
i'm guessing since i am 11th on the list, mine will be in the second batch (hopefully) or the third?
DHM1
DHM1
Thread Starter #153
thats awesome..
Well I have everything to build/ship the first 5. The rest of the material should be done at Waterjet the next day or two. I'm hopping to ship everyone's but maybe the last 2-3 mid next week
Russ
Etyrnus
I plan on doing some logging before install stage 1, after install stage 1, and stage 2.
Here are some logs.
2015 Fiesta ST
DHM280 EFR Kit
20psi of boost
93oct
about 260whp
Thanks
Russ
So I know there is probably an obvious answer to this, but forgive me my ignorance of how my car works. If you have a bigger turbo like the DHM280 EFR but the boost is roughly the same as stock (20 psi), how does it make 260 whp? And assuming said obvious explanation exists, you would expect to see lower temps that what you got on a stock turbo at the same or perhaps even higher boost pressures, is that correct?
Izzy
Russ
Can they be painted in gold?
Oh Sweet, Im #1.
Can't wait to get this thing installed. Planning on leaving it the standard finish because Notaracecar.
Oh Sweet, Im #1.
You know as #1, you're legally obligated to post install pics, right? With great power...
