- Member ID
- #1084
- Messages
- 89
- Likes
- 20
After cooking ATE Super Blue on my Wilwood BBK yesterday, brake ducts are definitely in order. Pedal went to the ground and I suspect ESC/Brake Torque vectoring has something to do with it as it was mainly my driver's front corner that was cooked. Speaking of which do you guys track with traction control/ESC fully off on the track?
[video=youtube;Z5bFpRBwdmw]https://www.youtube.com/watch?v=Z5bFpRBwdmw&feature=youtu.be[/video]
For the record my setup was ATE Super blue brake fluid, DTC-30 pads front, Ferodo DS2500 rear, SS lines all around.
What are the odds that the mechanic who initially bled these brakes did not torque down the bleeder enough so that at extreme heats the fluid started seeping/leaking? I generally DIY a lot of work but I get mechanics that I know to do stuff like brakes as I'm iffy with my understanding of hydraulics and don't want my pedal to go to the floor which is what happened here.
I will be upgrading to a different brake fluid perhaps Ferodo Super Formula or Motul RBF600 but I definitely want to look into better cooling. My plan is to remove the fog lights as they are pretty damn useless and also run a less aggressive front pad (something closer to the level of Ferodo DS2500) as the track I go to is not too hard on brakes. I've seen some on the forum who have cut a hole in the chin curtain under the bumper but I don't want to lose that ground clearance. I might get my local speed shop to fab me some backing plates with a spot for hoses too.
Has anyone figured out a way to disable torque vectoring without losing ABS etc.?
P.S. Anyone happen to know the torque spec for the little 1/4" bleeder screws on the Wilwood Dynapro 6?
