Can the Fist tow a small trailer?
I'm thinking of getting rid of my truck. It just sits. I use it once a week but only to drive it. I actually only need it to haul lumber or bags of cement like 6 times a year when working on a project in my yard and next summer when that project is finished, I plan to not start any more F'in projects!!. Can the Fist tow a small hitch trailer?
I was actually wondering this myself. The standard fiesta hitch kits look like they might run into the st bumper as it's a bit different
I was wondering the same thing for the same reason, but figured that when I need to do work like that I will just rent a U-Haul pick up. Save me from hurting the car and having to look at the receiver.......
R
Yah, but say I need two 4 inch x 4 inch x 8 foot posts, hate to rent a truck for just that. Now Home Depot and Lowes can rent the truck to me for $25, but then I have to make two trips (return the truck). Maybe get this small 4x6 trailer for $600
http://www.homedepot.com/p/Northstar-Trailers-4-ft-x-6-ft-Sportstar-1-ATV-Trailer-Kit-NS1/204187273?cm_mmc=Shopping%7cG%7cBase%7cPLA%7cD25T%7cTools&gclid=CITI6bT5xscCFYKPHwod4K8K5g&gclsrc=aw.ds
lessard.dcj
should be no problem. i plan on using my car to tow my motor bike around
R
get one of them hidden hitches where when it's off you can barley see it, it's just a square hole.
There's a guy that used his hitch for a small trailer for his autocross tires and what not over a multi-state trip. I don't see why you couldn't.
If you can fit 3 other 250 lb friends in your car, why not a small trailer with a small load?
dyn085
Keep it under the GVWR listed on the sticker in the door jamb and you'll be fine. It won't be much but it's definitely possible.
