- Member ID
- #3014
- Messages
- 131
- Likes
- 14
Waiting for the weekend to install!
First Impressions:
Catch can looks really solidly built
Plug at the bottom is pretty neat. Not sure if it needs teflon if it gets removed, but it's an NPT fitting
Pretty clever design to divert the inlet air though I'm not sure if the second tab/wing does anything.
Pre-cut hoses look super clean. Much much happier I chose this over cutting existing hoses
Things that were a little off, but really really minor things:
First Impressions:
- The free plush was actually an inflatable penguin
- The bottom is actually kind of difficult to remove. I used the bracket to get a little bit more leverage and it came off OK. Should be easier when installed.
- Mishimoto decal was missing part of the T.
- I might replace the hose clamps because I tend to prefer the variety with an extended tail so the worm gear system doesn't cut into the hose.
- Didn't get the fancy clear tube/package that's in the videos with all the snazzy "MISHIMOTO CATCH CAN" stuff on it. Only the white box
- Mishimoto logo is inconsistently oriented on the hose! They'll probably be in the same direction once installed though.
