CLICK HERE TO PURCHASE CHARGE PIPE KIT!
Charge Pipe R&D and Testing
Like I said, I will be blowing your minds with pictures and data today. Now it's time for the charge pipe upgrade.
We will be offering the charge pipes in two different flavors. With BOV, and without BOV. The kit that includes the BOV will come with a MAP adapter to provide a vacuum/boost source for the BOV mounted on the charge pipe. It will also include a billet CNC block off plate to put in place of the factory electronic BPV mounted on the compressor cover of the turbocharger.
Here are some pictures of the R&D process:
Hotside charge pipe to intercooler connection (kit will include T-bolt clamps)
Connection at the turbo
Running from the turbo to the intercooler, here you can see where the pipe bolts to the oil pan tab
Start of the cold side pipe off the intercooler
Where it connects to the pipe that runs up to the throttle body
You can see the path it takes up to the throttle body in the next pictures
Close up of the BOV location and the T-map sensor
Another look, plus a little peak from the first prototype intake I posted about earlier (which we aren't using)
Now onto the results.
This is a completely stock car with our charge pipes but I was running E30 during the testing as I was diagnosing a E30 issue with a tuning customer. Which is why the baseline comparison dyno is 200whp/287wtq.
Dyno:
Data: (Red stock piping, Blue MAP Piping)
Closer look at boost:
You can see that the spool is a hair later (.250 seconds slower to reach peak boost), but it carries boost out longer than the stock piping which explains the power gains.
Stock Peak Boost: 22.25psi
MAP Peak Boost: 22.45psi
Closer look at Charge Air Temp:
Our charge piping does run a few degrees warmer. This is to be expected when switching from plastic charge/rubber charge pipes to stainless steel. This is based on a 72° ambient temp +/- 1-2°.
Stock Min Charge Air Temp: 82.5°
Stock Max Charge Air Temp: 120.3°
Stock Average Charge Air Temp: 95.5°
MAP Min Charge Air Temp: 84.6° (+2.1°)
MAP Max Charge Air Temp: 123.9° (+3.6°)
MAP Average Charge Air Temp: 100.17° (+4.67°)
Here are some pictures of the final product:
Overview:
- Constructed of 304 Stainless Steel
- 100% direct factory replacement. Will work with all factory location intercoolers.
- 100% tig welded with back purge
- Precision Mandrel Bent
- Available with or without Turbosmart Vee-port BOV
- Available in RAW or Wrinkle Black
- Made in the USA
- Lifetime Warranty
Pricing:
Without BOV - $299.99 shipped
With BOV - $549.00 shipped (Will include billet CNC block off Plate, BOV, MAP adapter)
Add $65 for Wrinkle Black powdercoating
Will have product page links posted shortly to purchase! ETA is roughly 7-10 Business days to start shipping.
EDIT! Here are some more pictures of the kit installed!
Dyno:
Overview:
- Made in the USA
- Lifetime Warranty
Pricing:
