- Member ID
- #3412
- Messages
- 10
- Likes
- 6
hey folks, owner of OV tuning, www.ovtuned.com
Picked up a 2014 Black FiST as the new project car, and have finally decided what we are going to do. The idea sounds crazy, but this is our plan:
-We are going to retain the stock turbocharger, so that we don't loose low RPM response / torque.
-The downpipe / discharge from the stock turbo will flow into a V-band EFR 7163, along with a Tial 38mm EWG.
The 7163 will feed the stock turbo, which will be set to run about wastegate pressure. The 7163 boost psi will be static. the stock turbo will be managed so that it is not working nearly as hard as it does stock.
This way we should be able to retain stock like response, without any top end loss. Already gathering parts and have the 7163. Plan is right now not to go past stock fueling system (if possible)
Couple of questions for you forum folks, if anyone knows...
- highest safe Rev limit for the 1.6 ecoboost? We plan to turn it at least 7500 rpm.
-stock fueling HP capacity, haven't really found a reliable answer as to just how far the stock fueling will go
starting with a bone stock FiST, and going all out ^_^. Right now car is still stock as we're figuring it all out.
