COBB Releases New v220 OTS MAPs - Major Update
St. Clair Shores
Not sure if you already checked this...But go to "Setup" on your AP and check to make sure "Auto On / Off" is turned back on....Just for reference mine has been working fine and I have latest AP updates downloaded....
I have not checked it, I will go in and check it after work. I figured it was a setting or something, but I just noticed it wasn't working right yesterday, so I will check it out.
thanks for the quick reply and info!
PhoenixM3
Colorado Springs
Hey Braden, when is the "next major release"? The issue is a real PITA when on the highway when using the cruise control a lot.
I drove to Switzerland last month (about 600 miles each way) and kept bumping between OTS stage 1 map and the economy tune. Pretty annoying. I don't mind the visual verification of each map when using the cruise control, but trying to pass someone when you think you're cars is in stage 1 when it really is in the economy stage is a little un-nerving.
PhoenixM3
Colorado Springs
I've never accidentally switched a map, but I turned off the "rolling map switch" feature. In order for a map to be switched I have to be at a complete stop and that's when I'll check once in a while to see that it's on the correct map especially when I'm running on ethanol.
Oooh. I just read this. I guess this will fix my map swapping issue too.
Vallejo/Fairfield
Thought I briefly share. I just recently went back to factory settings. The difference between factory & AP updated stage 1 is huge. I need to get this appointment over with & re-install. [?|]
Gloucester, VA
Thanks for the update Ian!
Hey Ian,
Loaded the v221 fix to the AP and the ATR update. I rebuilt my v220 map using the v221 Stage 3/93 as the base map. So..., the problem isn't fixed. I've pretty much gotten accustomed to the glitch, so I don't switch maps unintentionally now.
BoostBumps
BoostBumps
Arizona
Thread Starter #128
Hey Ian,
Spoke with Braden earlier and he says a new ATR update is currently in QA for final review and should be released "very shortly" which should fix the rolling map switch "on-the-fly" bug which was in the v220 maps....As I understand it resaving a "modified" v221 map in the current ATR program version will not resolve the bug....
In the mean time I just simply went into ATR / Configuration / Rolling Map Switch / and selected Disable which now only allows maps to be switched when stopped and works ok this way...
