- Member ID
- #517
- Messages
- 1,437
- Likes
- 315
So, after two years with the FiST, I've run into a bit of an issue. In the state of Texas when you purchase a new car, you don't need to have the car inspected until your second year of ownership. For me, that means my time for state inspection was the month of November. I have the complete Cobb stage 3 set up on my car. It failed inspection due to the 02 sensor and cat being "offline" (ie: not ready). I didn't know it was off completely, so my bad. I'm then told by my pro tuner that the Cobb OTS map also disables the sensor as well.
Mmmm k. So if I go back to the stage 0 map and drive the neccessary 60-70 miles to reset the sensors, I get a cat efficiency CEL almost immediately because the voltage readings are too high with the freer flowing downpipe. I'm guessing there's no way to alter the voltage targets so that you don't throw a cat efficiency CEL.
If the only solution to this is to pay someone to R&R my downpipe (twice), to be able to get my car inspected, then my love affair with the FiST has come to abrupt end. I know in the old days there were ways to alter the voltage outputs to the sensors so that freer flowing cats would not be so sensitive to throwing a CEL.
What sucks is that Texas now uses integrated inspection and registration. I cannot get my car registered until I can pass the state inspection.
I don't feel comfortable switching to stage 0 map, driving the car 60-70 miles so all the sensors can relearn and then pop a CEL, then drive to the inspection station and reset the code(s). I've been told I can do that or swap to the economy mode map "and hope for the best".
The folks at Cobb Plano or Cobb Austin have not responded to my email so I don't know what to think. Anyone have any experience with this (specifically Texas people here)?
