Thread Starter
#201
Thread Starter
#201
Seems like no one with a 2015 actually has this installed?
Maybe I'm not doing it right...? Did any of you get stuck at this part:
https://www.youtube.com/watch?v=-eaVP4EsZRg
Unfortunately, this was around 10 pm, so I couldn't take advantage of daylight to help shoot a clearer video.
Believe me, it's being pushed up as far up as it can go, because of the plastic piece in the video restricting it from going up any more.
And it's being pushed back (toward the radiator) as much as it can go, because the backside of the crash beam is restricting it.
If kicking and whacking it in isn't enough force to get that in, I don't know how this can be considered a "drop-in" IC.
I shouldn't even need to be putting that kind of force to install it...
:origin()/pre07/a338/th/pre/i/2013/091/6/e/my_brain_is_full_of_fuck_in_hd_by_lemmino-d602afj.png)
http://youtu.be/Ze3hthGRbRo
Take a screwdriver and pry it into place put the bolt in and make it work.. Seriously, I guess you aren't very mechanically inclined (not that that's bad) if you can't even install an intercooler. This thread is turning into a 2J witch hunt.
If smacking the intercooler doesn't work use logic and find out what needs to be cut/trimmed/removed to make it fit.
