I purchased a Schroth QuickFit Pro harness back in Feburary and finally got around to installing it this weekend. (Only purchased the driver side as I can't afford both at the moment. They run about $370 a piece!). I went with the Pro option because it is HANS device compatable and I plan on using my HANS during track days. I also liked the camlock buckle over the standard and there's an option to add a sub belt later if I want.
Install was a breeze. Anyone with a little wrenching skills should be able to complete it in about 45 minuets. Only tools required are a T46 head socket and socket wrench although I only had a T45 and it worked fine. Hardest part of the install was removing the bottom half of the rear seat which is pretty easy on these cars.
I've had them on the car for a few days now and I have to say they are well worth the money. They hold you into the seat so well. You are able to concentrate on your driving instead of holding yourself in place. I can see these helping with fatigue greatly. Almost makes me not regret not getting the recaros...ALMOST... They adjust very easily and look very good in the car. They are also surprisingly comfortable too. They don't dig into you like other harness I've used.
These belts are DOT Certified so you COULD use them everyday but I wouldn't. When fully buckled in the stereo is a little hard to reach. If you buckle yourself in before closing the door you are not going to be closing the door. Those are the only drawbacks really.
I'll post a more in depth review when I get a little autocross and track time in but initial impressions are very good. I'll keep everyone posted!
