I started detailing my PB 2015 today and had a revelation about getting an ultimate shine. I did a good wash, clay bar'd, and then started on a polish.
I used my DeWalt rotary with 3M Perfect-it Ultrafine Machine polish on a 8" 3M ultra-fine foam pad. This is the second time I've done it since I've owned the car. This time, I had some fine scratches that I tried to remove by adding pressure and building heat. I should have just gone to a courser compound and polished it out. Instead, what I found happening was that this good, hard, clear coat became plastic and started moving. The ultra-fine polish wasn't course enough to wear the hard clear coat away, it just heated it up and moved it to where there was a little wrinkle of moved clear coat on that spot I was trying to work out.
So, I took my experiment further. Full speed, about 10 pounds of pressure for 3 passes. Then followed by just machine pressure at lower speed for 3 passes.
The orange peel goes away! Not fully, but after about 3 treatments, I think it will be mirror smooth. And, it does it without grinding it away.
I'll finish tomorrow with Poor Boy's EXP sealant and Natty wax and post some photos.
