- Member ID
- #2134
- Messages
- 4,097
- Likes
- 948
Easy question(maybe). What is the maximum(normal day) engine oil temp you have read?
Here is the reason, the MP215 Mtune unit has limits on which gauges. Oil temp is not one of them(boo). Where I want to run my gauges limits me to 1 1/2" (38mm)face size, and well that limits gauges you can find. I found many digital 37mm but meh, I like analog (call me old fashion). Now in truck and tractors I have used water temp gauges to monitor oil temp as they would rarely hit 260 but could the Fist go higher? Limit I have is about 280. Coolant temp I have seen max out @ 230 so from some quick math the oil should be around there maybe 20 more. This is not to determine if the car is over heating but to see if the car is up to temp before I request more out of it than I should (aka wot).
![Smile [:)] [:)]](/images/smilies/smile.png)
